For Your Information
Old Jan 31, 2021 | 06:58 PM
RalphP's Avatar
RalphP
Default For Your Information
The starter stud and bolt for a 1988 Dakota 3.9 is a 7/16-14 thread into the bell housing.
And the stud works better on the top so you can slip the starter on and let that support it while you're getting everything else threaded and torqued.
And ... they do stock bolts to suit at Advance, for when the bolt falls out and your truck won't stop because the starter motor is hanging in the air.
Not that I have personal knowledge of that or anything ... *ahem*
RwP
Old Feb 1, 2021 | 12:06 PM
Shaderabbit's Avatar
Shaderabbit
Did the hanging starter take out a brake line or what?
Old Feb 1, 2021 | 07:32 PM
93 ragtop's Avatar
93 ragtop
Are you using the old style large Starter or the newer smaller starter? On mine, 4wd, it was a bear swapping the orig. One in there. My next one will be the smaller one. Ain't fighting that battle again.
Old Feb 1, 2021 | 08:07 PM
ol' grouch's Avatar
ol' grouch
RwP
That's on a par with sticking a screwdriver into an over pressurized dunnage bag in a rail car that's been humped. Push the valve in and release pressure first.
Old Feb 1, 2021 | 10:51 PM
RalphP's Avatar
RalphP
For all above -
1) Nope, didn't hit any brake lines; it was actually hanging on the stud, which the engine assemblers back when put UNDER the starter.
2) OEM sized; and yes. On my list (for after the body work and paint if possible!) is a new high torque starter to get something I can work in and out when necessary. But. I'll have to do the valve cover gaskets AGAIN (damn gaskets leak like sieves at the back!)
3) I wouldn't know, but I'd trust in venting ANY bag.
RwP
Old Feb 16, 2021 | 11:19 AM
93 ragtop's Avatar
93 ragtop
Hey Ralph,
Wanted to share my last blunder, (that I know about)
See anything wrong with this seal?
Old Feb 16, 2021 | 11:56 AM
RalphP's Avatar
RalphP
Originally Posted by 93 ragtop
Hey Ralph,
Seal looks backward to me.
If not, is it driven in too far?
RwP
Old Feb 16, 2021 | 12:07 PM
93 ragtop's Avatar
93 ragtop
Yep, backwards... That was fun changing out with the engine already bolted in.
Old Mar 9, 2021 | 02:43 PM
LuckytheDakota's Avatar
LuckytheDakota
that's on a par with sticking a screwdriver into an over pressurized dunnage bag in a rail car that's been humped. Push the valve in and release pressure first.
