HELP! whistling noise from engine on acceleration
Old Apr 16, 2021 | 02:09 PM
RalphP's Avatar
RalphP
Originally Posted by Zebraitis
1) Catalytic converters are very expensive because they use rare metals. To maximize the surface area of these rare metals, they are spayed on a grid system (like you saw above, except not broken) that the exhaust gasses must pass. This grid system gets heated to very high temps during use and the idea is that anything that is supertoxic will be burned up as it passes through it. (the catalyst - the rare metals- coverts the toxins in the exhaust.) The O2 Sensor checks to see how well that is happening and provides feedback to the engine.
Actually, no.
The upstream O2s are used to feed back how well the engine is running, true. They work with, or without, a catalyst.
The DOWNSTREAM O2s mostly monitor that there's a change from the UPSTREAM O2s; but only the 1996 1st Gens have a downstream O2 sensor.
RwP
Old Apr 16, 2021 | 05:15 PM
Originally Posted by RalphP
Actually, no.
RwP
Well, 96 and newer. Anything OBDII will monitor the cat(s).
Old Apr 16, 2021 | 06:11 PM
RalphP's Avatar
RalphP
Actually, no.
RwP
"Only the 1996 1st Gens" - there aren't any 1997 or newer 1st Gen Dakotas
OTOH, the 1994 Thunderbird 4.6 used downstream O2s since it was basically OBDII (missed a couple of OBDII monitors, but can be read by most any OBDII scanner using the OBDII port on the ... passenger side of the dash.)
RwP
