91 Dodge Dakota 3.9l starts but no accerleration
Old Dec 23, 2021 | 01:03 PM
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
Lotsa possibilities there.
Think the first thing I might do is check fuel pressure......
Old Dec 23, 2021 | 01:49 PM
onemore94dak's Avatar
onemore94dak
What is the fuel pressure when it is running before you press the gas pedal?
Then what does fuel pressure do when you increase the throttle?
If it idles could the injectors still be a problem? This is a TBI right?
Old Dec 23, 2021 | 04:30 PM
RalphP's Avatar
RalphP
Yes, the 91 is a TBI.
I'd check fuel pressure (14.5PSI) and fuel flow. I do not find it in a cursory read of the FSM; what I REMEMBER (which may be wrong; if someone has it documented, feel free to chip in!) is that it should flow a litre a minute minimum when you bypass the fuel pump relay.
RwP
Old Dec 23, 2021 | 04:46 PM
volaredon's Avatar
volaredon
Converter plugged?
