Dual fan conversion
Old Dec 15, 2022 | 11:39 AM
dylan21's Avatar
dylan21
Default Dual fan conversion
I got a 96 dakota and I just purchased duel fans and it came with a thermoswitch but I have no open areas to put it in was wondering if I can just splice the wire from the relay to one of the 2 sensors on the intake manifold I know the left on is the one going to the ecm and the right one is going to the gauges so would splicing into one of them turn the fans on I do not want to put the thermoswitch into the upper radiator hoses trying to make it look nice under the hood
Old Dec 15, 2022 | 02:53 PM
Nope. They are sensors, not switches, so, they constantly pass at least some current.
Old Dec 15, 2022 | 03:36 PM
dylan21's Avatar
dylan21
what if I splice the gauge sensor wire into the ecm wires sensor and take the other spot for the thermoswitch for the fans
Old Dec 15, 2022 | 03:43 PM
I believe they operate at two different voltages. PCM sensor will have 5 volt input, and somewhat less than that output. Guage sensor I think is 12 volts, and it grounds thru the intake.... so, prolly wouldn't work. Maybe drill/tap another hole for the switch?
Old Dec 15, 2022 | 04:44 PM
dylan21's Avatar
dylan21
Have to find a spot in the Hughes airgap intake but that’s going to have to be a another day project I’ll just do the coupling in the upper radiator hose for it useless I can find any-fitting or something at home depot
Old Dec 15, 2022 | 05:03 PM
On chevy heads, there was a spot to screw in temp sensors, when they stopped using those style sensors, they just put pipe plugs in there, and called it a day. Anything like that on your heads?
Old Dec 15, 2022 | 05:27 PM
dylan21's Avatar
dylan21
No ports in the heads only area is on the bottom part of the block and I believe it’s a drain plug it’s taped up at the bottom theirs 2 on the block one on each side
Old Dec 15, 2022 | 07:37 PM
For a fan switch though, I would think you would want it to read coolant temp in the radiator....... or at least, very close to it. Hence the adapter for the upper hose.....
Old Dec 16, 2022 | 09:16 AM
dylan21's Avatar
dylan21
It would do the job rn until I can drill a hole into the intake coolant jacket
Old Dec 30, 2022 | 04:41 PM
dylan21's Avatar
dylan21
My truck has the electric radiator fan relay under the hood since the 2.5l come with electric fan could I tap into that relay to get them to turn on
