Transmission
Old Jan 14, 2023 | 06:37 PM
Bundy's Avatar
Bundy
Default Transmission
Have a 93 dodge dakota v6 automatic. Had the transmission re-done. A friend took it out and picked up. Sooo, having trouble hooking it up to rear cross member. Not sure if there was a plate on the transmission. Does anyone have a picture I can see. Maybe I'm missing something.
Old Jan 14, 2023 | 11:50 PM
Tw1ZZLER's Avatar
Tw1ZZLER
You might be missing the transmission mount. In my 1994 Dakota, It is a bracket with 3 bolts that attach to the transmission and a soft piece in between (like a mini suspension) and two bolts that go through the crossmember. It should go above the crossmember.
Looks kind of like this but not exactly:
Old Jan 15, 2023 | 09:37 AM
Bundy's Avatar
Bundy
[QUOTE=Tw1ZZLER;3558484]You might be missing the transmission mount. In my 1994 Dakota, It is a bracket with 3 bolts that attach to the transmission and a soft piece in between (like a mini suspension) and two bolts that go through the crossmember. It should go above the crossmember.
Old Jan 15, 2023 | 09:38 AM
Bundy's Avatar
Bundy
Ok. I have something that looks like that. But how does it bolt to the transmission?
Old Jan 15, 2023 | 10:22 AM
onemore94dak's Avatar
onemore94dak
IDK but if you look through the FAQ section there are a 95 and 96 Factory Service Manuals. download one and look it over it may help you figure it out.
Or go to Bishko website and buy a copy on CD for your year.
Old Jan 15, 2023 | 09:05 PM
bronze's Avatar
bronze
Originally Posted by Bundy;[url=tel:3558505
3558505[/url]]Ok. I have something that looks like that. But how does it bolt to the transmission?
Let me know if you still need to know. I can crawl under my ‘93 and take a couple photos for you in the morning.
Old Jan 17, 2023 | 12:16 AM
TheSneeze's Avatar
TheSneeze
I am about to remove a '94 trans. I can take photos if you need them.
Old Jan 17, 2023 | 08:23 AM
Bundy's Avatar
Bundy
That would be awesome. Thank you
Old Jan 17, 2023 | 08:24 AM
Bundy's Avatar
Bundy
That would be great. Thank you
Old Jan 17, 2023 | 09:28 AM
onemore94dak
clicked wrong thread
