Error Code Help
Old Jan 19, 2023 | 06:18 PM
KennyD714's Avatar
KennyD714
Default Error Code Help
I had an error code 15 come up and was wondering what need to be done to fix it, as well as would that cause the vehicle to go into limp mode?
Old Jan 19, 2023 | 09:04 PM
Vehicle speed sensor (VSS) -signal
Not getting vehicle speed. Though I am not entirely sure what limp mode would actually be on an OBDI Dak.....
Maybe telling us what you are driving would be a good idea?
Does your speedometer work?
Old Jan 19, 2023 | 09:08 PM
ol' grouch's Avatar
ol' grouch
What year do you have. It's a 1995 or earlier. On OBD I it's usually the speed sensor or circuit. Is your speedometer working?
Old Jan 20, 2023 | 08:55 AM
KennyD714's Avatar
KennyD714
I have a 1994 3.9l automatic, the speedometer isn't working and won't shift after 3rd gear. Originally thought it was the shift solenoid but that wasn't one of the error codes that had came up.
Old Jan 20, 2023 | 09:12 AM
First three gears are purely hydraulically controlled. TCC and O/D should be controlled by the computer. If it doesn't know how fast you are going, you won't get O/D.
Your speed sensor should be on the tailshaft of the trans, (or, t-case, if you are 4x4) It's a gear driven signal generator. But, it seems the PCM isn't getting the signal.
Old Jan 20, 2023 | 09:27 AM
KennyD714's Avatar
KennyD714
Okay, I will look into that and replace the sensor and see if that resolves it, or if it's something with the wiring between the sensor and PCM
Old Jan 24, 2023 | 04:59 PM
KennyD714's Avatar
KennyD714
Replaced the speed sensor and everything is back to normal.
Old Jan 24, 2023 | 05:35 PM
That works. Good Deal!
Old Jan 24, 2023 | 05:40 PM
KennyD714's Avatar
KennyD714
Yes it is, only a 35 dollar fix for something I thought was gonna put me back several hundred when I first was having problems and didn't have any idea what the problem was yet.
Old Jan 24, 2023 | 08:17 PM
bronze's Avatar
bronze
I like when a plan goes together.
