Tail light rats nest
Old Apr 15, 2023 | 07:08 PM
JMcafee's Avatar
JMcafee
Default Tail light rats nest
Okay, so long story short, I bought a doa, Dakota. I got it running and driving. Yesterday I noticed the reverse light was out (originally every light was working). So I figured, no problem. Oh boy was I wrong. I'm guessing the previous owner wired up some dolley to the truck because there are a bunch of wires going through the tail light housing, wiring harness, and some connectors feeding upwards into the bed. The current driver-side reverse light socket is not factory. It looks like they wired up a Dorman universal tail light to it in it's place. There's a green ground wire taped to the outside but that ground is ran up to inside the bed and held up with a screw. I wish I took some pictures to prevent my horrible description but my question is this. Would a standard tail light replacement socket work for the reverse light? I can't find a "reverse light socket" anywhere on the internet.
Old Apr 16, 2023 | 01:22 AM
bronze's Avatar
bronze
Originally Posted by JMcafee;[url=tel:3564931
3564931]Okay, so long story short, I bought a doa, Dakota. I got it running and driving. Yesterday I noticed the reverse light was out (originally every light was working). So I figured, no problem. Oh boy was I wrong. I'm guessing the previous owner wired up some dolley to the truck because there are a bunch of wires going through the tail light housing, wiring harness, and some connectors feeding upwards into the bed. The current driver-side reverse light socket is not factory. It looks like they wired up a Dorman universal tail light to it in it's place. There's a green ground wire taped to the outside but that ground is ran up to inside the bed and held up with a screw. I wish I took some pictures to prevent my horrible description but my question is this. Would a standard tail light replacement socket work for the reverse light? I can't find a "reverse light socket" anywhere on the internet.
I could not find one anywhere either. Ended up jury rigging the one I had.
Old Apr 16, 2023 | 08:57 AM
JMcafee's Avatar
JMcafee
Here are some pictures of what I’m currently looking at. Think the socket for the reverse light is toast. Might try to order the same thing and rig it up with a new one.
Old Apr 16, 2023 | 09:33 AM
I would be tempted to go alookin' for a rear harness. Car-part.com could help ya out.
Old Apr 16, 2023 | 11:16 AM
bronze's Avatar
bronze
Seriously. That thing is a mess.
Old Apr 16, 2023 | 05:19 PM
fatmike0684's Avatar
fatmike0684
Just wire in a regular taillight socket from Napa that fits the Dakota. They always have them in stock. Put the regular bulb in there as well so it makes both contact points.
https://www.napaonline.com/en/p/ECHLS6478?impressionRank=1
Old Apr 16, 2023 | 05:45 PM
JMcafee's Avatar
JMcafee
So upon further inspection, the wiring was pretty simple to figure out. He spliced into the harness (those little connectors on the harness wires) and ran, what I'm guessing, extra wiring out to whatever dolly or hauler he used. The grounds were put in and connected to I think a fuse box (which was blown). So I just snipped and taped up the excess wires that didn't need to be there and it looks a hell of a lot cleaner now. Now all I need to do is follow the make-shift harness that he zip-tied along the frame to the front of the truck and rip those out as well.
Old Apr 16, 2023 | 05:46 PM
JMcafee's Avatar
JMcafee
https://www.napaonline.com/en/p/ECHL...pressionRank=1
I'll look into that, thank you! Does it matter that the linked socket has 3 wires and the factory socket only has 2?
Old Apr 18, 2023 | 04:41 AM
fatmike0684
absolutely not. Since the harness and bulb will have 2 functions, you could probably hook both wires to hot. Just put bulb in and put truck in reverse. Play with the wires until you get the bulb to light up
Old Apr 18, 2023 | 08:12 AM
JMcafee's Avatar
JMcafee
sadly after some digging I’m finding out that the harness that goes to the rear driver harness either has a messed up ground or a short somewhere. Which would explain why he had been jumping them from the passenger side which works perfectly fine. So the rear harness was fine the entire time. >.> guess it’s time to do more digging. No idea how the heck I’d find the part itself.
