1995 Dodge Dakota 3.9L intermittent code 27-fuel injector circuit
Old May 5, 2023 | 03:48 PM
luke_airig's Avatar
luke_airig
Default 1995 Dodge Dakota 3.9L intermittent code 27-fuel injector circuit
I have checked each of the injector connectors with a noid light and each of the
six connectors show a flashing noid light.
Since the six injector connectors passed the noid light test does that confirm
there are no issues with the wiring from the PCM to the injector connectors and
the problem is one or more bad injectors?
Old May 6, 2023 | 10:26 AM
It may just be a poor connection at one of the injectors. Or, it may be a failing injector. Unfortunately, the code is pretty generic, and doesn't tell you WHICH injector it thinks is problematic.
