what is the problem
Old May 19, 2023 | 04:44 AM
fatmike0684's Avatar
fatmike0684
Unfortunately checking check engine codes won’t help you any. All that computer tells you is whether or not the circuits are plugged in. I had similar problems as you. Truck wouldn’t even stay running. I replaced crank sensor, when I pulled it out, I saw it was split down the middle. Replaced with new aftermarket, problem fixed instantly. A month later, I would get back fire under acceleration only while engine was cold. Again, only codes was 12 and 55. I replaced coolant temp sensor for computer problem fixed. While I had coolant temp unplugged I turned key on to see if it would even throw a code. Sure enough got a coolant temp sensor code. So yeah, checking codes don’t do squat if any sensor is bad. As long as it’s plugged in, computer won’t tell you anything.
Old May 19, 2023 | 01:01 PM
tjohn's Avatar
tjohn
So far as the PCM is concerned, there aren't any problems then. Ain't that fun? Check your fuel pressure, see what it looks like.
I,m going to O'Rielys to loaner tool -fuel pressure tester
Old May 19, 2023 | 04:25 PM
tjohn's Avatar
tjohn
Well got the tester for fuel pressure. Reads about 30 psi while on, when engine running it fluctuates between 40 psi & 35psi, fluctuates constancely not steady-bad fuel pump?
Old May 19, 2023 | 04:29 PM
Cycle the key a couple times, to thoroughly prime the system, (don't start the engine) what does it read?
Old May 19, 2023 | 04:31 PM
tjohn's Avatar
tjohn
stays at 30 psi
Old May 19, 2023 | 04:48 PM
But it goes up when it's running???
Old May 19, 2023 | 07:12 PM
tjohn's Avatar
tjohn
yes-close to 40 psi while fluctuating
Old May 19, 2023 | 07:18 PM
Hhhmmm..... That *should* be ok... though it's low when not running.....
