95 dakota 3 9l crank but no start
Old Jul 18, 2023 | 03:38 AM
RaymondMickles's Avatar
RaymondMickles
Default 95 dakota 3 9l crank but no start
I have a 95 dakota 3.9l and I thought I had a bad coil because I wasn't getting spark but I replaced both the coil and coil wire still no spark I'm getting power to the coil so I can't figure out why I'm not getting any spark from it
Old Jul 18, 2023 | 07:08 AM
Does the fuel pump run while cranking the engine? It will prime for three seconds at initial key on, but, does it run after that?
Old Jul 18, 2023 | 12:34 PM
RaymondMickles
I just found out no it doesn't continue pumping while cranking the engine over I would greatly appreciate any help I can get
Old Jul 18, 2023 | 01:21 PM
RaymondMickles
Old Jul 18, 2023 | 01:46 PM
Probably bad crank sensor then. Use ONLY a genuine mopar sensor. These trucks don't play nice with the aftermarket fellers.
Old Jul 18, 2023 | 02:10 PM
RaymondMickles
Okay I'll give that a try and see what happens and I'll let you know either way thanks
Old Jul 19, 2023 | 07:14 PM
RaymondMickles
Probably bad crank sensor then. Use ONLY a genuie mopar sensor. These trucks don't play nice with the aftermarket fellers.
It's alive thank you very much for the assistance you are a life saver I hope you don't mind but I know where to turn from now on when can't figure out what's wrong Thanks again I can't say it enough
Old Jul 19, 2023 | 08:52 PM
Glad ya got it runnin'. I hate not having my truck.
