Help me source 96 5.2 auto engine harness?
Old Aug 29, 2023 | 10:42 PM
bronze's Avatar
bronze
Lol. Pretty much the same way I did it. I used a microdriver too. Ground the tip a little so it slid past the tab easier. Then wrapped a piece of tape around the shaft to use as a depth gauge to ensure I didn’t go too deep. Used a piece of credit card to put behind the tab so it didn’t bend back too far. I was kinda hoping you had a magic trick but sounds like you were pretty much doing close to the same thing. Haha. I often thought it mighta been easier to get a used connector with the wires still in it (that’s what I did but pulled the wires out) and just lop off the harness wires then sit there and solder the 55 wires back on the connector.
Old Aug 30, 2023 | 11:02 AM
onemore94dak's Avatar
onemore94dak
I got a set like this one
Amazon Amazon
off eBay when I needed to change out a connector on my old Ram50. It was very cheap, less than $10, as are the tiny aluminum keys.But if you are gentle they work once you figure out which key to use.
Old Aug 30, 2023 | 12:56 PM
bronze's Avatar
bronze
Originally Posted by onemore94dak
I got a set like this one https://www.amazon.com/Vignee-Termin.../dp/B08295ZWL2 off eBay when I needed to change out a connector on my old Ram50. It was very cheap, less than $10, as are the tiny aluminum keys.But if you are gentle they work once you figure out which key to use.
Link not working. UPDATE: Worked when I clicked on it in the quote section. Whatever.
Old Sep 6, 2023 | 12:13 PM
Flounderguy's Avatar
Flounderguy
This is the back probe kit I got from Amazon.
