Timing chain sprockets?
Old Oct 1, 2023 | 09:03 AM
RWEJR's Avatar
RWEJR
Nope. But, you should be able to just pull the distributor, and re-index it.
HeyYou thanks sorry for a few lines in my question don't know what I was thinking. Got up and running working the bugs out, ?were some info for setting the timing with the timing light.
Old Oct 1, 2023 | 09:31 AM
Moparite's Avatar
Moparite
You don't set the timing, It's controlled by the pcm. You do need to set the fuel sync witch is what HayYou's instructions describe.
Old Oct 1, 2023 | 10:08 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by RWEJR
I got to hand it to ya those are some very important lessons to learn 😂😂.
I was taught them by Wile E. Coyote, SOOPER Genius as I was peeling him off my car door.
Old Oct 5, 2023 | 09:59 AM
RWEJR's Avatar
RWEJR
Default Thanks
Turn the engine so #1 cylinder is at TDC, in firing position. (both valves closed.) The distributor will have a notch that you need to align the rotor with. Usually, the cap is also marked with which tower is for #1.
Thanks again for the time and guidance got my cylinder heads on everything back together still working on pitally stuff.
But it on the road again.
Old Oct 5, 2023 | 11:51 AM
ol' grouch's Avatar
ol' grouch
Ah yes, the gold old "piddly stuff". That's why my anticipated 2 week overhaul on my truck took 4 months. Well that plus the heat and me being lazy.
Old Oct 5, 2023 | 07:07 PM
bronze's Avatar
bronze
Is it the heat or are we just old?
Old Oct 5, 2023 | 09:17 PM
ol' grouch's Avatar
ol' grouch
No, it's the heat. I've never been able to handle it very well and as I've gotten older, it's gotten worse. I still like the cool and even cold weather. Just not the heat.
Old Oct 5, 2023 | 10:34 PM
bronze's Avatar
bronze
I used to love heat. Now I hate it. Too old for that crap.
Old Oct 6, 2023 | 06:47 AM
Too hot? Nope, I don't go out.... Too cold? Nope, then either. It used to be that weather didn't bother me.... (I did roofing in the summer when I was in college....) But, as I have aged, I have become less tolerant of weather extremes. Too hot, and the brain simply doesn't work, too cold, and EVERYTHING hurts. Give me mild weather, 60's and 70's, with a slight breeze, and I am happy. MS plays hell with my desired lifestyle.
