Timing chain sprockets?
Old Sep 28, 2023 | 04:15 AM
RWEJR's Avatar
RWEJR
Default Timing chain sprockets?
I just replaced the cylinder head's on my 93 Dodge Dakota le 5.2 magnum. Question is I got the timing off 180 digrees and can't seem to get tdc back is there anyway to get the sprockets back in line without removing the timing cover.
Old Sep 28, 2023 | 06:41 AM
Nope. But, you should be able to just pull the distributor, and re-index it.
Old Sep 28, 2023 | 11:44 PM
ol' grouch's Avatar
ol' grouch
Did you pull the distributor when you pulled the engine apart. Like HeyYou said, reindex the distributor. That's the only way I can think it would be off.
Old Sep 29, 2023 | 06:43 AM
RWEJR's Avatar
RWEJR
To answer the question yes does that make a big difference? ,I thought I had to but didn't. What's the process two reindex distributor? Thanks for your time.
Old Sep 29, 2023 | 07:14 AM
Turn the engine so #1 cylinder is at TDC, in firing position. (both valves closed.) The distributor will have a notch that you need to align the rotor with. Usually, the cap is also marked with which tower is for #1.
Old Sep 29, 2023 | 08:10 PM
bronze's Avatar
bronze
I learned something today. 😊
Old Sep 30, 2023 | 04:52 AM
Moparite's Avatar
Moparite
Old Sep 30, 2023 | 12:41 PM
RWEJR's Avatar
RWEJR
Care to share with rest of the class? What you learned I mean.
Old Sep 30, 2023 | 09:33 PM
ol' grouch's Avatar
ol' grouch
Ooh! I learn stuff every day. Don't reach into a toaster while it's working, it's orange for a reason. Don't fry bacon in the nude. Never lick a steak knife. Lot's of things.
Old Oct 1, 2023 | 08:51 AM
RWEJR's Avatar
RWEJR
I got to hand it to ya those are some very important lessons to learn 😂😂.
