Fuel pump Relay location 1989 dodge dakota 1989
Old Oct 23, 2023 | 05:28 PM
mlally's Avatar
mlally
Exclamation Fuel pump Relay location 1989 dodge dakota 1989
Im a little confused is the ASD relay and the fuel pump relay the same, I get a mix of opinions online
also, does any one have a diagram they can provide or exact location for fuel pump relay?,
Thanks for your help or any advice,
Appreciate it< your time!
Old Oct 23, 2023 | 06:57 PM
bronze's Avatar
bronze
ASD = Auto Shut Down. Never known it to be the same as a fuel pump relay. Not certain on an ‘88 but on my ‘93 the relays are in a black box mounted on the left fender near the battery in the engine compartment.
Unless if you mean they’re the same spec. Yes they should be.
Old Oct 23, 2023 | 10:01 PM
onemore94dak's Avatar
onemore94dak
It's the only fuel pump relay on Rock Auto
https://www.rockauto.com/en/catalog/...ing+relay,3380
