Instrument cluster swap
Old Feb 21, 2024 | 10:37 AM
EliBBBB's Avatar
EliBBBB
Default Instrument cluster swap
Hey I have a 93 instrument cluster that I was looking to put into a 88 Dakota. Will it work or do I need major modifications? It does have the tach which is why I'm looking to swap
Old Feb 21, 2024 | 10:49 AM
89sportboi's Avatar
89sportboi
From googling, it looks like 89-93 is listed as having the same dash but I found a pic of the back of the 88 dash and compared it and it looks like it would theoretically work... everything is in all the same locations as the 89+ so I think you may be in luck. The only snag I can think of is if your truck has the signal for the tach already wired up or if you would need to run the signal wire to the cluster. If so you should be able to just grab/find those parts, run the wire up wire it in accordingly and boom you have a tach
Old Feb 21, 2024 | 07:01 PM
Does the 88 use a VSS, or is there a physical cable drive for the speedo?
Old Feb 21, 2024 | 07:05 PM
89sportboi's Avatar
89sportboi
My 89 has a cable so I’d assume the 88 does as well. From looking at pics of the 88 dash vs the 93 it looks like they both use the cable
Old Feb 21, 2024 | 07:21 PM
93 should be electronic???? I think the cable went away in 94 on the full size trucks.... But, not sure how accurate that is.
Old Feb 21, 2024 | 10:37 PM
EliBBBB's Avatar
EliBBBB
I tell you guys what. I appreciate the recommendations so far. Ima send pictures of what I got in the morning. Possibly compare my own dash to the one I got but long story short I got all the connectors for the back side of the 93 dash as well as the entire cluster. Would that prevent me from having to run a wire into my own cluster?
​​​​​​ I'll send pictures of the three clusters i have to help clear confusion if it does help.
Old Feb 21, 2024 | 10:42 PM
EliBBBB's Avatar
EliBBBB
I believe said cable that you speak of is also on my 88. If I'm not mistaken it runs from the back of the cluster to the front left wheel backing somehow 🤷🏽‍♂️ idk I'm not great with these things.
Old Feb 21, 2024 | 10:44 PM
EliBBBB's Avatar
EliBBBB
Chrysler, or Dodge just was like **** it throwing these things together from what I seen ngl
Old Mar 4, 2024 | 04:42 AM
EliBBBB's Avatar
EliBBBB
Default *Update*
On the left is the 96 on the right is the 93. I'm trying to get the 93 instrument cluster swapped into the 88 I have. I do apologize for such a late response I've been rather lackluster with providing info and a response. One thing I could note for distinguishing the difference between the photos of the two is that I still have the parking thing in the 93 cluster vs the other. As well as the gray cavity/whole in the back of the 93
