Ignition key switch wiring colors
Old May 3, 2024 | 10:02 AM
talfrey42718's Avatar
talfrey42718
Default Ignition key switch wiring colors
I need to know what wires go to what on my 1st generation dakota. It is the 7 pin plug i am trying to wire in a new aftermarket ignition switch for it and need to know what colors are what.
The yellow wire is currently ran to a toggle switch ik that is the acc power wire
Old May 3, 2024 | 05:21 PM
Have a look here, should have what ya need.
Old May 3, 2024 | 07:59 PM
talfrey42718
this had the diagram I needed but now I need to know if I need to run a ground to wrap around my new universal key switch i am going to be hard wiring into my harness
So far i have the red, dark blue, yellow, and pink/black wires ready to hookup but idk which spot to put them someone please help me get my daily back up and going
Old May 3, 2024 | 08:47 PM
I don't think the ignition switch grounds anything. It simply provides power to various places, depending on key position.
Old May 3, 2024 | 08:59 PM
talfrey42718
if you look at the schematics diagram there it says the system is ground through steering column attachment and im tapping into the stock harness so I just want to make sure I don't need to run a ground
Old May 3, 2024 | 09:19 PM
The switch completes circuits for power on the supply side. It won't hurt anything to ground the body of the switch, but, I really don't think it is necessary.
Old May 3, 2024 | 09:54 PM
talfrey42718
is there anyway you could tell me what wires would go where on the switch
Old May 4, 2024 | 10:27 AM
I have no idea which terminals do what on the switch itself. Why not just replace the failed switch?? Would be a lot easier I would think.
