Help! 93 Dakota Throttle cable
Hi, thanks for your help. Its taken awhile to sort this problem out! I finished up buying a 94 throttle cable and it doesnt fit! Ive had to make a bracket for the throttle body to hold the cable in place because that end is too short and the pedal end is too long so my pedal is a lot closer to the floor. Im still in the process of modifying the end from the old one which will give me a adjustable length so I can do away with the bracket and return the pedal to the correct height! I will try to post photos when this is done, sorry fo4r the delay but ive had 2 lots of major surgey in between posts. All the best Trev.
