Help! 93 Dakota Throttle cable
Hi all, does anyone know if the throttle cable from a 94 3.9 v6 auto will fit a 93 ? Or does anyone have one new or 2nd hand that I can purchase ? Many thanks in advance.
I've done some searches and the 93 TV Cable does not come up. I have two ideas. 1. Remove the one you have and measure it 2. talk to a dealership parts department.
I really do not think the motors change enough that they altered a part like the TV cable.
Thank you, the only problem is we dont have a dealer network in the UK, I think I will measure it and if its roughly the same length order the 94 from Rock Auto ! Many thanks Trev.
Trending Topics
I think you can probably email a US dealer to ask.
OK just found this. It was bugging me that the info is so hard to find
IDK if it is the right one but #1 seems to be it. It is 'currently unavailable' but there is a part number which hopefully can get you info on whether or not the 94 cable will work
https://www.moparpartsgiant.com/part...on%20Cab%202WD)
EDIT- Browsing around I found a site that claimed these guys have after market cables. https://lokar.com/
IDK if it is the right one but #1 seems to be it. It is 'currently unavailable' but there is a part number which hopefully can get you info on whether or not the 94 cable will workhttps://www.moparpartsgiant.com/part...on%20Cab%202WD)
