Turn signal issues
Ok the "splice you're talking about is actually a big plug in the firewall. I found my loose wire on the cab side of that plug.
[img alt="See the green wire
"]https://cimg8.ibsrv.net/gimg/dodgeforum.com-vbulletin/1500x2000/img_20250510_180033487_ae_dd6f89c8234ee55f7e27e53d 030fd7878eec446e.jpg[/img]
See the green wire
Now I need to figure out how to reattach it to the plug.
See the green wire
See the green wire
Don't know why the image won't load, but there is a plug that's about 3" x 3" on the firewall with a rubber boot protector. It's got a long machine screw holding it together. When it's taken apart there's about 30 blade terminals. There was a wire pulled loose on the cab side. Definitely turn signal wire. I bypassed the plug and spliced the wire to the two wires on the other side of the block in the same position. Turn signal works now, but not with the headlights on.. lol.
No, and the corner marker light is supposed to flash as well. I think the block plug is more than just a simple plug, I think it has to go through it for everything to work properly. I'm going to see what I have to do to reconnect the wires to the plug tomorrow. Might have to break out the soldering iron. I'll update when I'm done.
It's fixed!!! The loose wire in the plug had another wire in the same connector slot, so I pulled that wire and added it to my bypass splice. Everything works as it should now. Thank you so much for the help. So thankful that this electrical nightmare is over.
