Steering Rack
Old Dec 20, 2025 | 09:57 PM
  #41
ol' grouch's Avatar
ol' grouch
Originally Posted by bronze
An update on these new tires.
There is a noticeable difference in the handling of these new tires vs the old. The front end is splashy. Takes more steering adjustment to keep it between the lines. There are occasions when it seems the front end has a mind of its own. I don't want to make it sound like it's out of control. It's not. It's just splashier than my old 18-1/2 year old tires that had 1/8" of tread left. Maybe these new tires need to wear in a little or my old tires were like driving on slicks. But, still no front end chatter.
Are the new tires radial or bias ply? I rebuilt the front end on my old 1954 Coronet completely and it still followed cracks in the pavement and wandered all over the road. I got some later rims and put radials on the car and that all went away. I also had a truck once that I bought 2 new tires and put them on and it wandered at speed. It turned out I put 2 radials on it and the original tires that were still good were boas ply. The two DON'T mix well.
Old Dec 21, 2025 | 09:10 AM
  #42
Can you even GET bias ply tires these days??
Old Dec 21, 2025 | 11:30 AM
  #43
ol' grouch's Avatar
ol' grouch
A lot of trailer tires are bias ply as well as OTR truck tires are sometime bias ply. Semi's use bias due to being able to recap them. Radials can be recapped but only a couple of tires sizes per mold. Bias you can do a bunch of different sizes.
Old Dec 21, 2025 | 11:48 AM
  #44
bronze's Avatar
bronze
It's the same size tire that I replaced and the pressure is the same (35psi). As far as I know they are radials. As for following the grooves I'm not sure I can say one way or another TBH.
Old Dec 22, 2025 | 02:33 PM
  #45
ROCKYTOPTN's Avatar
ROCKYTOPTN
1993 Dodge Dakota LE, 5.2L, A518 auto trans, RWD, 190,000 miles, original owner
My rack and pinion is leaking. I think I know where it is leaking from but I'm not 100% certain so I'm not gonna say where. I think I will do a dye test to make sure. Meanwhile, I am trying that Lucas power steering leak stop and it does not appear to be working yet. I say yet because you need between 12 - 24 ounces of it and so far I'm less than 12 ounces. I'm kinda letting it leak out and refill with straight Lucas as needed. If this doesn't solve the problem then I think I'm looking at replacing the steering rack. Our late Ralph always recommended the Rack Doctor but I think they went bellyup. Their website is down and I see lots of complaints online. That said, is anyone aware of other rack sources for these Dakotas? I'm talking rebuilds. I want to say these auto parts stores have Cardone (if any at all) but I'm weary of them. I see Rock Auto deals with Cardone rebuilds but also peddle new ones...Edelmann, Lares, BBB Industries. Wouldn't have a clue if any of these new ones are worth a crap TBH. The price range on these new ones are $277 - $469. I'd be interested in opinions on the new ones as well. Thanks ahead of time.
I got one off of EBay around 300 life time guarantee but you have to send them your old one. Take the motor mount nuts loose that are under your frame, and jack up the engine and get the rack loose and then remove the bolt from the steering column. Good luck. But I got a 89 Dakota can’t be much different. If you don’t rack it correctly you may end up having to take it to an alignment shop. Watch a couple of You Tube videos
Old Jan 2, 2026 | 12:27 PM
  #46
bronze's Avatar
bronze
Do the tires tend to follow the grooves in the road? Are they the same size as the previous set?? What pressure ya runnin' 'em at?
UPDATE ON SPLASHY TIRES:
I think you were on to it HY. This morning I checked the air pressure on those four new tires I had put on a week and a half ago. They were all reading 40 psi. Supposed to be 35 psi (per the door sticker). I always run them at 35 psi. I always check when they're cold (overnight or usually longer). Not sure how they ended up at 40 psi (I didn't add or subtract air from them, they were what the tire shop put them at) but that's where they were (I use a quality dial air gauge). I took out 5 lbs each. The test drive revealed no splashiness. Wouldn't think 5 lbs would make that much of a difference but apparently it does. Like I said, it wasn't a major problem, but noticeable. Pulling 5 lbs put it back to what i was used to.
Old Jan 2, 2026 | 01:00 PM
  #47
Pretty significant difference between 35, and 40. May not seem like much, but yeah, it can make a pretty significant difference.
Old Jan 2, 2026 | 07:41 PM
  #48
ol' grouch's Avatar
ol' grouch
A shop that I let change my oil likes to run tires up to maximum pressure. I always let some air out or it'll wear the center tread out. Maximum is just that, MAXIMUM.
Old Jan 3, 2026 | 10:42 AM
  #49
bronze's Avatar
bronze
Yeah, I pump mine up to 35 psi (the max). Seems whenever i get around to checking my air pressure it's down to 32 psi. So I'm always running 32 - 35. Got 55,000 miles on my last set of Michelins so it must be working.
