cat and timing chain
Old Jan 20, 2006 | 02:10 AM
bionic4.0's Avatar
bionic4.0
Default RE: cat and timing chain
what would you do if you had my situation
v6 flow master single in duel out hollowed cat no tail pipe it is has no pipe after the muffler
it is to loud
Old Feb 9, 2006 | 01:05 AM
bdodge_445's Avatar
bdodge_445
I recently had custom exhaust done to my 92 Dakota, I cut everything off from the front of the cat back. I put in a 3" glass pack 21" long and nothing else. This is by far the best sounding and performing exhaust I've seen for 3.9's. be sure not to cut off your O2 sensor otherwise it will run like crap. After the glass pack Y the pipe off and run duels from there. Only do this if your state doesnt check emmissions, but like i said leave the cat off and a 21 inch glass pack is all you will need. It'll only run you about 70 bucks for the set up if you do it yourself including pipe and the GP.
Old Feb 10, 2006 | 08:54 PM
360DakotaPwr's Avatar
360DakotaPwr
That is good. For the V6 I would stick with a single or a single in dual out. By keeping the cat, you will still have an ok amount of back pressure, but dont go with too loud of a muffler.
