360 swap.
Old 02-28-2006 | 03:42 AM
OneBadKota's Avatar
OneBadKota
Default 360 swap.
I did the 360 swap on my Dakota. Doing transmission work, etc this week. While in the process I was going to attempt to hook up my stock tach and speedometer since it's been without for a bit. I know it's possible to get the stock tach to wire up, but can the stock speedo be wired to work properly? Any help is appreciated. [sm=smiley20.gif]
Old 02-28-2006 | 10:27 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: 360 swap.
You can wire anything if you know what wires to hook it to. What year is your truck? Some of them a cable controlled instead of electric. Reguardless, it reads off the tail shart of the tranny.
Old 03-01-2006 | 02:10 PM
OneBadKota's Avatar
OneBadKota
It's a 1995. I was told if I looked at the wiring schematics I could figure it out, but I've been too busy lately to go search them out.
Old 03-02-2006 | 03:00 AM
360DakotaPwr
I believe 95 is electronic, but i could be wrong. I dont have a wiring diagram.
Old 03-04-2006 | 02:44 AM
stantheman's Avatar
stantheman
im doing the same to my 96. is yours an x-cab? what trans did you use and did yoiu use the factory trans crossmember and mount?
also drive shaft? ive got a 99 r/t motor and a 46re trans waiting on taxes to get back to finish the rebuild. got to find a floor shifter also. mine is a standard at the moment. wanted to keep it standard but ran across the 46 for free.
Old 03-04-2006 | 03:10 AM
injmopar's Avatar
injmopar
Why not plug the hole and change the column and gain some room on the floor.Or you could go to a cable shifter
Old 03-04-2006 | 02:05 PM
OneBadKota's Avatar
OneBadKota
ORIGINAL: stantheman
Yes, it's an extended cab. I used an LA 360 out of a Mid-70's Ram. I am using the stock A500. Everything is pretty much stock on my drivetrain, except I am in the middle of rebuilding the transmission and using a 3000 stall converter and trying to find me an R/T rear end.
Old 03-04-2006 | 11:08 PM
360DakotaPwr
You guys can use whatever tranny you want. You just have to find the driveshaft to fit. If need be you can swap the tail shafts and housings from a 500 to a 518 and vise versa to allow you to run the driveshaft you have now if need be, but it is complicated if you are not familiar with auto trannys. I believe the 46re is the heavier one, but I dont recall those numbers. Im familiar with A500 and A518.
You should be able to use the stock crossmember and mount reguardless of either tranny.
And I too would plug the hole and get a column shift.
Old 03-08-2006 | 03:06 AM
JDakota92's Avatar
JDakota92
ORIGINAL: 360DakotaPwr
yes, the '95's are electronic, as I believe all of '94-'96's are of that body style.
Old 03-09-2006 | 02:10 AM
stantheman's Avatar
stantheman
the 46re came out of a 99 1500 and the 360 came out of a 99 r/t dakota. dont want to hassle with changing the column and all the linkages. at the moment i am looking for a cable shifter. Found another post somewhere that said would just have to mod the bracket a little. Really dont have the need for extra floor space, i put 99 durango factory leather buckets and console in a couple of months ago.
Quick Reply: 360 swap.
