Weird
Old Apr 1, 2006 | 10:09 PM
dak3.9's Avatar
dak3.9
Default Weird
When i went to go drive my truck this morning (It was still kind of dark.) I went to turn on my lights right after i started my truck and they didnt turn on. Only my parking lights. A little while later, i turned them on and they finally came on. Any ideas on why this happened?
Old Apr 2, 2006 | 01:28 AM
kdh97602's Avatar
kdh97602
Default RE: Weird
dirt in the switch, happened to me once after driving through arizona. clean the switch, it should work 100%
Old Apr 2, 2006 | 01:33 AM
dak3.9's Avatar
dak3.9
Default RE: Weird
My truck is a 90, I have to pull a little bar back to turn my lights on. Unless your talking about something in the wiring?!?
Old Apr 2, 2006 | 03:38 AM
kdh97602's Avatar
kdh97602
Default RE: Weird
exactly, the switch is a bar that you pull back in mine also. the area where the bar disapers into can collect dust and dirt and eventually cause the switch to foul and not work properly.
Old Apr 2, 2006 | 12:30 PM
dak3.9's Avatar
dak3.9
Default RE: Weird
How did you get behind to the "switch"?
Old Apr 2, 2006 | 06:58 PM
stantheman's Avatar
stantheman
Default RE: Weird
you have to pull the dash bezel. its a bunch of allan or torx screws all around the trim. had to replace my whole switch assembly cuz one my prongs was burnt. ended up being the switch. when you get it off check your connectors for burnt connections.
Old Apr 3, 2006 | 12:08 AM
dak3.9's Avatar
dak3.9
Default RE: Weird
It hasnt done it since saturday morning when this happened. They've worked since. I'll take a look at it.
Old Apr 3, 2006 | 02:01 AM
kdh97602's Avatar
kdh97602
Default RE: Weird
just if it happens again, take care of it! here in california its a $140 ticket and 1 point on the driving record to drive at night w/o lights on. I found that out the hard way.
Old Apr 3, 2006 | 07:36 PM
dak3.9's Avatar
dak3.9
Default RE: Weird
that stinks. Thanks for the info everybody.
Old Apr 7, 2006 | 07:15 AM
moparmanewulm's Avatar
moparmanewulm
Default RE: Weird
i have a 93 3.9 sport and i have had the same problem. first time it happend the switch burned out i could smell it in the cab. and sence then i have had to put a new one in about every 3 months. thank god for a lifetime waranty. The light still once and a while wount come on. so far it has worked for me to pull the switch in and out fast a couple of times and then wait about a min and they come on. also some times they flash right after start up and moving.
