Vibration on a 93 dakota sport 4x4
Old Apr 6, 2006 | 10:00 PM
moparmanewulm's Avatar
moparmanewulm
Default Vibration on a 93 dakota sport 4x4
I have a vibration problem that started in the rear end and know i am feeling it in the steering wheel. it only happens between 2 and 3 grand sometime hire. cleaned all dirt and stuff from the rims, rear drum all the drive tran and still have problem. Anybody got any ideas?
Old Apr 7, 2006 | 12:37 AM
harry_angel69's Avatar
harry_angel69
Default RE: Vibration on a 93 dakota sport 4x4
Check your u-joints and maybe the pinion bearing.
Old Apr 7, 2006 | 06:57 AM
moparmanewulm
I have check my u-joint on the rear axel. and that is fine. there is no play in the shaft at all when trying to rotate it. How would i know that my bearing is out with out ripping it apart? I do have bad cv joints and the boots. could that be my problem that they are so far gone that they are causeing the vibration. The vibration increases in 4wd.
Old Apr 8, 2006 | 12:23 AM
moparmanewulm
its my spider gears in the rear end. thanks for the help.
