Fuse box layout
Old Nov 22, 2014 | 05:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by lisadenise68
fuse box layout
Check the FAQ in this section, just a few posts above this one. Also, don't be scared to start your own thread.
Old Jan 14, 2015 | 11:19 PM
Bikerdad's Avatar
Bikerdad
Default Radio
Did you get an answer I'm having the same problem
Old Aug 19, 2017 | 09:43 PM
DodgeDakota2000's Avatar
DodgeDakota2000
Default Fuse box AUX spot for added equiptment
Originally Posted by FoxRocker
how easy is it connect to the fuse box for an accesorie, such as fog lamps or a LED kit, I want to use the main power source and the fusebox, this will eliminate a ton of wires comming seperatly of the battery terminals
There is a space in fuse box that says AUX it can be used to power additional needs as you stated above with out going off the battery terminals. Make sure you are using a compatable fuse for equipment added.
Old Mar 19, 2019 | 03:56 PM
Sam Gettman's Avatar
Sam Gettman
Default Just extra
Just adding a couple pics for reference from my 1994 Dakota SLT with the V8
Old Mar 21, 2020 | 03:09 PM
Dwain Buchanan's Avatar
Dwain Buchanan
Default 2005 reader fuse
It went out a couple months ago,I'm standing here trying to find the fuse that operates that little lite,or is it part of cigarette lighter
Old Mar 21, 2020 | 04:01 PM
RalphP's Avatar
RalphP
Might want to ask in the appropriate forum - this is for 1987-1996 Dakotas, and we won't have anywhere NEAR the same wiring!
But here's a wild idea - check ALL the fuses!
RwP
Old Sep 18, 2024 | 07:39 PM
Jon2288's Avatar
Jon2288
Default No brake light or trim signal
Hello my mother I law had a 2002 dodge Dakota V8 and has no turn signal or brake light I check the fuses and what I could look up they are good and brake light bulbs are good. Any help please.
Old Sep 18, 2024 | 09:23 PM
Do they do anything at all?
