Perfromance enhancements
Old Jul 16, 2006 | 06:53 PM
skynyrdcat's Avatar
skynyrdcat
Default Perfromance enhancements
Just curious if anyone would share some performance enhancing tips. Advance timing, cut a hole in air filter, etc (you know, the inexpensive kind).
I'd like to get a couple of cheap horses out of my dakota. I may even spend a hundred or two for a proven technique / part.
Thanks in advance!
Old Jul 17, 2006 | 12:46 AM
dodgerules86's Avatar
dodgerules86
Default RE: Perfromance enhancements
Definitly gotta get a fart can exhaust, that and some stickers, oh yea, and an underbody kit! Those things together will net you about 30HP.
No, but seriously, cold air intake.
Old Jul 17, 2006 | 03:25 PM
skynyrdcat's Avatar
skynyrdcat
Dang, I thought I was gonna get somewhere with the stickers!
Any retailer / distributor you recommend?
Is this something I can find at the local parts store?
Old Jul 17, 2006 | 06:49 PM
dodgerules86
I don't have any add-ons on my Dakota, so I can't personally recommend anything.
I've heard K&N CAI's are good. You could also visit the Gen 2 board and see what they recommend. (We got the same 3.9L as they do).
Old Jul 17, 2006 | 08:33 PM
jonnymagnum's Avatar
jonnymagnum
i would go with an exhaust and intake. its amazing how much power you can get by just doing that.
________
JAILBROKEN
Old Jul 19, 2006 | 08:18 PM
Sneezer's Avatar
Sneezer
ORIGINAL: skynyrdcat
Thanks in advance!
I assume you have a GenII since you are posting here. Couple cheap mods you can do:
Remove the weather plate in front of the air cleaner duct - passenger side behind the grille.
Replace your airfilter with a drop in K&N. Voila - instant CAI and more flow.
Remove the IAT sensor from the intake manifold, drill a hole in the square inlet to your aircleaner housing and install it there. It will read cooler temps and richen the mixture a tad.
Remove the CPS sensor on the back of the engine and slot the bracket. You can now move the sensor forward and back a smidge, which will physically advance or retard the timing.
Got a dremel or angle grinder? Port/polish your TB. Grind off all the ridges and open the bores so they are straight. Good for a big increase in airflow.
Those are the cheap ones.
Get a junkyard dual fan out of a V6 Contour/Mystique or a dual fan from a 98-03 Concorde/Intrepid. These fans are thin enough to fit in a GenII, yet provide plenty of cooling. Fab up a cheap fan control, maybe spend $100 tops for the whole thing if you are smart about it. That way you can ditch the power robbing clutch fan.
