do you use any additives
Old Oct 20, 2006 | 08:53 PM
89 dakota's Avatar
89 dakota
Default do you use any additives
Does anybody use any sort of additives like for the oil or trans? If so what do you use?
Old Oct 20, 2006 | 09:47 PM
dodgerules86's Avatar
dodgerules86
Default RE: do you use any additives
For the engine:
I add a gray bottle (15 ounces) of CD-2. Its supposed to help with engine wear and the rings (I don't have a problem with either however, when I got the truck my grandpa recommended I add it every oil change). Its also supposed to quiet the engine down (such as valve train noise).
I have also added some MMO (Marvels Mystery Oil). They add some MMO (and another liquid) to their diesel fuel to help lube their lift pumps.
I have used, and would recommend both.
For the transmission:
I'm kinda leary about using anything in the transmission. Chryslers ATF is enginered specifically for their transmissions. It has a certain "gritiness" to it (which Dexron lacks, which is why it shouldn't be used), and of course, if something screws that up, its not good on the transmission.
However, before I service a transmission (and I mean not just the filter, I do the filter and change out ALL the fluid [disconnect the return line from the transmission cooler]) I like to run some SeaFoam thru there. It's suppsed to break up the varnish in the lines (I run SeaFoam only before a flush because otherwise that varnish might still be circulating in the transmission and stuff)
Other than that, I run some fuel system cleaner every couple thousand miles. I've been forgetting to do a SeaFoam engine treatment, but I've heard good stuff about that. (I'll do one after the first of the month, and make a post )
*edit* In fact, speaking of the devil, they just had a thread over in the Ram section about running SeaFoam. Here ya go.
Old Oct 21, 2006 | 12:53 AM
jonnymagnum's Avatar
jonnymagnum
I used to use lucas in my old 88 dakota 3.9 it would quiet the valve noise and give me more oil pressure. and I use it in my new truck the odd time now. and I would recomend it.
________
INDIAN COOKING
Old Oct 22, 2006 | 04:53 PM
89 dakota's Avatar
89 dakota
i tried the seafoam engine treatment and it seems to have worked but i didn't get as much white smoke as everyone else says they have gotten. Not that it's a big deal but my truck has 350.000 kilometers on it and i thought that i'd have alot more carbon build up. I'm gonna try thier tranny treatment next time.
