Turn Signals,Brake Lights & Hazards not working
Old Dec 27, 2006 | 01:12 AM
tnowlin's Avatar
tnowlin
Default Turn Signals,Brake Lights & Hazards not working
My 1994 dokota turn signals and brake lights and hazard lights stoped working but the brake light on the tail gate still works. I checked the fuse and the blinker module they are OK. What else could I check?
Old Dec 27, 2006 | 03:01 AM
Mr_Shorty's Avatar
Mr_Shorty
Default RE: Turn Signals,Brake Lights & Hazards not working
I would venture to say pretty certain that it is the turn signal switch mounted on the column... The brake switch is wired directly to the three brake light so that it doesn't blink like the others... But the other lights all run through the blinker switch mounted on the column. I assume that your running lights work correctly, which would say the wiring harness is functioning and not unplugged.
Later Daze,
Shorty
Old Dec 27, 2006 | 08:51 AM
tnowlin's Avatar
tnowlin
Thanks for the quick response, I'll check it out let you know
Old Jan 7, 2007 | 11:29 PM
tnowlin's Avatar
tnowlin
I changed the turn signal switch on the column.That fixed my tunn signals but not my brake lights or flashers. The running lights and my center brake light on my tail gate have always worked. What else I can try?
Old Jan 8, 2007 | 12:30 AM
BOOMER_87's Avatar
BOOMER_87
for your flasherslook for a second flasher however the hazzards and brake lights are on the same circuit
Old Jan 8, 2007 | 04:04 AM
BAnders's Avatar
BAnders
it should have two flasher cylinders, caddy corner to each other above the fuses
