Ground Problem!
Ground Problem!
Ok where do I start... I decided the dinky ground wire connecting to the fender needed to be upgraded since I am running 1/0-Gauge positive amp wire. When I did so now the truck slightly bogs down in a pulsating rhythmic way but ONLY when I take off from a stand still and do so really slow barley touching the gas. Also sitting in park if I ever so slightly touch the throttle it will do it, otherwise once I'm past a certain low RPM (no tach) it completely goes away, or under that RPM like idling:
So I used a piece of amp wire, well the new terminal I had is meant for a single wire centered. So I simply used a Dremel and grinded all the paint off the metal on each side of the centered wire divet all the way between the two clamp bolts, seems like it would work legit since it is now making a full contact?
The ground wire going from the fender to the battery was literally the same thickness as that dinky wire running downward:
I took the Dremel to ALL surfaces including the battery post, terminals ends, fender, etc then applied silicone electrical grease between all contacts...no luck. Is it possible the ground going to the fender has to be smaller than the one going to the steering pump mount?
No it doesn't need to be smaller. I don't have a great explanation but maybe since you increased the negative maybe the positive side is weak. Or maybe it is just a coincidence.
Did you change the ground wire back to the small one to test your wire change theory?
Just to let you know I upgraded my Battery to fender cable as well. Also I threw one on to the frame rail.
I also upgraded my ground to the fender in hopes of not getting shocked anymore when i get out of my truck and touch any part of the truck on the outside. But i still get shocked lol. So if anyone can tell me how to keep the electricity in the truck and not in me that would be very helpful lol.
Oddly enough it cured itself overnight? No idea what happened. I think something needed to adjust to the higher current possibly? If I ground my amplifier to my cab wall which ground is it using more the fender or steering pump mount? Frame ground sounds like a good idea
Trending Topics
I'd highly recommend soldering them as well. The vibrations/movement from the motor and travel can really loosen things up.
Also, did you replace your big three? 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis
good write up on this upgrade
The absolute ground of your electrical system is not your neg battery terminal, but the case of the alternator. Assuming the alternator is properly bolted to the engine, your block to chassis ground is your most important ground. It's usually one of those pansy braided flat cables from somewhere lower down on the block to the chassis.
