Trans temp gauge using factory gauge
Old Jun 2, 2012 | 09:55 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Default Trans temp gauge using factory gauge
I have a mechanical temperature gauge in my turbo-charged mini-van. So I turned the factory idiot temp gauge into a trans temp gauge because I didn't need two engine temp gauges. In my Dakota I didn't want to add another gauge so instead I installed a switch to switch between the engine temperature and the transmission temperature using the same gauge. I'm going to be towing a mini-van from AZ to CA and a car back to AZ next week. There are a couple of hills on I-10 so I wanted to be able to monitor my transmission temperature.
A 5.2/5.9 engine coolant temperature sensor installed in a brass T and installed in the transmission to cooler (trans fluid out) line.
Engine temperature selected, ambient today was about 110* and I have a 180* thermostat.
Transmission temperature selected.
A.J.
Old Jun 3, 2012 | 01:57 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool, simple method.
Old Jun 3, 2012 | 08:13 AM
dobaroy's Avatar
dobaroy
That was a great idea that you did there. Wish you could have a deep transmission pan that would hold a few extra quarts of fluid, that would also help.
Old Jul 11, 2013 | 05:48 PM
rx7_dude2003's Avatar
rx7_dude2003
Best reading is in the pan!
Old Jul 11, 2013 | 06:20 PM
AZ 360 Dakota
Fluid in the pan can become stagnant. I based my decision on temp sensor placement on engine temp sensor placement. I used the line going TO the trans cooler just like an engine has the engine coolant temp sensor in the radiator hose going TO the radiator.
Old Jul 11, 2013 | 07:03 PM
Tom A's Avatar
Tom A
Section Moderator
Cool idea. Too bad that crappy gauge doesn't give any actual temperature readings.
Old Jul 11, 2013 | 10:05 PM
shadowthedakota's Avatar
shadowthedakota
awesome idea
Old Jul 12, 2013 | 08:13 PM
moe7404's Avatar
moe7404
on the old 727s in Park it didnt flow coolant through the cooler. dont know about the newer ones. so your reading in Park may be off. just an idea.
Old Jul 12, 2013 | 08:22 PM
AZ 360 Dakota
Ya but it gives me an idea of what it is. I know where 200* is so it's more of a reference.
A lot of vehicles hardly flow in park so I am aware of that. My concern is when I'm towing.
Old Jul 12, 2013 | 08:28 PM
moe7404's Avatar
moe7404
i think you are doing real great. you found a solution and fixed it easily. tons better than nothing. i wish i could still work on my truck. check out this external filter.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
