factory radio removal
Old May 9, 2007 | 04:19 PM
mtgrady1's Avatar
mtgrady1
Default factory radio removal
i have a 2002 durango and an wondering how difficult it is to remove the factory stereo. whether orf not i would have to take apart the entire dash. any info, directions, or pictures would be great
Old May 9, 2007 | 06:49 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: factory radio removal
yea sorry to tell you, the entire dash has to come out, we had to replace the contols for the heat/ac on my moms 02 and the entire dash had to come out, its a real PITA but it can be done, just be careful not to brake anything and you should have no problems
Old May 9, 2007 | 07:02 PM
Mean Green's Avatar
Mean Green
It should only be the shroud that cover the stock head unit then a few screws. Then again you have the newer interior so don't quote me on that.
Old May 10, 2007 | 06:20 AM
IndyDurango's Avatar
IndyDurango
It is the face and a few screws. Not the entire dash just for a radio.
IndyDurango
Old May 10, 2007 | 10:14 AM
mtgrady1's Avatar
mtgrady1
mine doesnt have a face around the radio it looks like the dash is all one piece.
Old May 10, 2007 | 05:01 PM
IndyDurango
That "all one piece" just pops off. Then you see the radio screws. Easy actually.
All '98-'00 interiors were the same and then all '01-'03 interiors were the same. However, each still had a "all one piece" that just pops off
IndyD
Old May 11, 2007 | 02:51 PM
mtgrady1's Avatar
mtgrady1
it deffiniltly doesnt just pop off. i think i have to take off the two pieces under the steering wheel and below the a/c controls to try and get the piece around the radio out
Old May 11, 2007 | 06:03 PM
shrpshtr325
THE ULTI-MOD
ORIGINAL: mtgrady1
that is correct and iirc there are a fex screws under neath the dash if you follow it down under the radio and ac/heat controls and tey have to come out then the whole dash from the drivers door to the glove box comes off, there might even be a screw in the glove box that you have to take off
Old May 12, 2007 | 06:47 AM
IndyDurango
Still that's just 'pops off' when compared to someone telling you to take the entire dash out. A few screws here and they, I should have said, it is easy and left it at that.
The front face on the dash should just pop off, no screws.
Nevermind.
Good luck.
IndyD
Old May 12, 2007 | 11:21 PM
shrpshtr325
THE ULTI-MOD
yes there are i think 3 screws under the heat/ac controls, and 3 under the steering wheel, and then the entire dash should come off from there
