99 dodge durango wont shift out of 1st PLEASE HELP
Old May 10, 2007 | 03:39 AM
kascutt's Avatar
kascutt
Default 99 dodge durango wont shift out of 1st PLEASE HELP
hi everyone ok hear is what happened went to work in the mouning everything was fine shifted fine everything never had a problem with it before there is no check engine lite on,went to go home from work put it in reverse it was fine then put it in drive and it would not shift out of 1st gear, the trans never slipped or anything what can be the problem PLEASE HELP!!!!!!!!
THANKS
ken
[/align]
Old May 10, 2007 | 06:22 AM
Mean Green's Avatar
Mean Green
Default RE: 99 dodge durango wont shift out of 1st PLEASE HELP
1) How's your fluid level?
2) When was the last time you changed your tranny fluid?
3) What kind of tranny fluid do you use?
Old May 10, 2007 | 12:49 PM
hydrashocker's Avatar
hydrashocker
Also there could be a problem with your Govenor Switch could be gone or hung up.
Old May 11, 2007 | 06:13 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
and also check the speed sensor on teh unersid of the transmission, mine went bad and the truck wouldnt shift right, if i had let it goe it might have gotten that bad, tis like a 15$ sensor
Old May 12, 2007 | 06:50 AM
IndyDurango's Avatar
IndyDurango
No shifting at all? I'd say you have a bands issue in the trans that need adjusting (assuming no breakage). As asked by Mean Green, things can be fine but if you are not having regular service on the trans, it won't stay fine for ever.
IndyDurango
Old May 12, 2007 | 04:34 PM
kascutt's Avatar
kascutt
thanks everyone so much for the input i just dont want to take it to a tranny shop if it is just a sensor or something i could change out myself and they can say i need a new tranny or something,well first of the fluid level is fine i used the recomened in the users manual and the fuid was changed last year ,also where would the governor switch be located and how can i tell if thats the problem and what might be the symtoms of it being bad?as for the speed sensor where would that be located and something as little as that can make it do this,and as for the band issues is that something that would have to be donne by a tranny shop and what would bw the symtoms of that?like i said i dont think the tranny is gone because i had no problems with it shifting or anything befor this it just happened all the sudden thank you all just want to get it fixed i miss my truck lol
ken
[/align]
Old May 12, 2007 | 07:55 PM
Mean Green's Avatar
Mean Green
Your bands can be adjusted along with a normal servicing. The speed sensor is on the rear axle and I have no clue on the governor switch's location.
Old May 12, 2007 | 11:18 PM
shrpshtr325
THE ULTI-MOD
yes there is a speed sensor on the rear axle, but there is also one on the transmission, it is on the drivers side, and should be the only thing with a wire on it accessible from underneath the truck, and that made mine shift better bc mine was shifting hard, and late before i replaced it, mayber it will help and good luck with it, let us know what the fix is
