Coolant Temp Problem
Old May 13, 2007 | 01:42 PM
samsammy23's Avatar
samsammy23
Default Coolant Temp Problem
My engine coolant gauge indicates that the temp is way too hot, it's all the way to the right. It then comes back into normal range, sometimes going up and down in temp. This is at city driving speeds. It does not do this when driving on the highway. It has not boiled over either. I have already put in a new thermostat with no change. What is my next step? Is there a sensor somewhere?
Thanks.
Chad.
Old May 13, 2007 | 05:29 PM
hydrashocker's Avatar
hydrashocker
Default RE: Coolant Temp Problem
There is a coolant temp sensor. On the 5.2L and 5.9L it is right by the thermostat on the left about a inch away.
Old May 13, 2007 | 07:01 PM
Mean Green's Avatar
Mean Green
YOu may just need some more coolant.
Old May 14, 2007 | 06:17 AM
IndyDurango's Avatar
IndyDurango
At highway speeds you are pushing enough air to keep it cool. That is why it is okay then. If at city speeds you are all the way to the right, I'd get it taken care of right away. Running to hot is very bad long term ans something is obviously wrong.
Bad stat, low fluid, blockage, etc.
IndyDurango
Old Jul 18, 2007 | 10:39 PM
samsammy23's Avatar
samsammy23
I would like to add that the heat is directly connected to the position of the temperature gauge. When the gauge is way to the right, my heat does not work, just cold air. As the gauge goes back to normal range, the heat works fine. Any other ideas?
Chad.
Old Jul 20, 2007 | 02:44 PM
Frankyoz's Avatar
Frankyoz
Have you tried replacing the thermostat?
Old Jul 20, 2007 | 02:57 PM
Kensai's Avatar
Kensai
I would check your fan clutch, fluids, if both of these check, it may be your water pump?
