Changing tranny fluid
Old May 16, 2007 | 06:28 PM
deerang's Avatar
deerang
Default RE: Changing tranny fluid
thanks for the link......however it was mentioned that adjusting the bands wasn't necessary for the 4.7L
Old May 17, 2007 | 12:33 AM
master tech's Avatar
master tech
Site Moderator & Tech
The 545RFE Transmission has two filters and use silicone ( RTV ) for the pan, There is no pan gasket at this time!!!! Be sure to install the o-ring filter right, If you don't you will be sucking air not fluid.
