p1491 Service Code
Old May 19, 2007 | 09:07 PM
zylozx's Avatar
zylozx
Default p1491 Service Code
I have already replaced the Relays and still my fan does not work properly..when i have this code....what should i check next....
Old May 19, 2007 | 09:46 PM
ATsGCSRT8's Avatar
ATsGCSRT8
Default RE: p1491 Service Code
Check all your wiringfrom the fan to the PCM. Look at all the connectors and make sure everything is plugged in and the connectors aren't broken.
Old May 20, 2007 | 03:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck the big fuses in the PDC, it maybe a 30 or 40 amp fuse. I had a ck engine on for the fan circuit, Thats when I found a blowen fuse. Cleared the codes. No more ck engine lite.
