crank and shaft sensors
Old May 20, 2007 | 09:42 PM
eahrayo's Avatar
eahrayo
Default crank and shaft sensors
Hello do everyone. Just checking to see if anyone can help me. My engine light is on and the mechanic said it was the crank and shaft sensors. Can anyone advice where these sensors are located in order to change them myself. I would be saving over $300. Any information is greatly appriciated. Thanks.
Old May 20, 2007 | 09:48 PM
eahrayo's Avatar
eahrayo
Default RE: crank and shaft sensors
My bad. I have a 2001 Durango with the 4.7L.
Old May 21, 2007 | 08:07 AM
Mean Green's Avatar
Mean Green
I can't find that in my manual any help on where it would be guys? After I get an answer I can post up the page/s from my manual.
Old May 23, 2007 | 03:26 AM
orlandozfreak's Avatar
orlandozfreak
if you are referring to the CKP and CMP (crankshaft and camshaft position sensors respectivly)
the CKP is mounted under the pass. side exhaust manifold (very easy to get to, PITA to get out)
the CMP is mounted on the underside of the pass side head (suggest removing airbox to make it a lil easier, not needed though)
both have 10mm bolts holding them in, and remember to oil up the o-rings on the new sensors
Old May 23, 2007 | 03:45 AM
master tech's Avatar
master tech
Site Moderator & Tech
If both sensors are bad, they are not that hard to replace , cam sensor is on the right head by the air cleaner and the crank is also on the right side of the block next to the starter, you may need to remove the starter to get to the sensor.
Old May 24, 2007 | 09:40 PM
orlandozfreak
ORIGINAL: master tech
um no.......the starter is on the opposite side of the block
do you see a starter? i dont..........
Old May 30, 2007 | 01:15 AM
eahrayo's Avatar
eahrayo
Thanks for all the info. As soon as i try I'll post the results.
