02 RT Tranny question
I pushed the throttle to the floor to speed through a yellow light and the tranny downshifted fine, but it quickly hit the rev limiter and would not shift up until a let off the throttle. Could a bad Throttle Posistion Sensor cause this? I know I need to replace do to a little rpm increase fluctuationwhile cruise is on.
Same problem with my tranny. After replacing both speed and output sensors, it seemed to help a little. But later I took my tranny in for its major scheduled maintenance (adjusting the tensioners, etc). Seems to help a little but overall, it can still slip on me during full throttle acceleration in drive mode. So just being safe, I now manually shift the tranny under full throttle so I do not get this slipperage during gear changes in drive mode.
