2 PCV valves?
Old Jun 3, 2007 | 03:24 PM
cesspool's Avatar
cesspool
Default 2 PCV valves?
I know the valve on the passanger side valve cover with the vacum line going into the intake manifold is the PCV valve, but what is the one on the other valve cover that goes to the air cleaner assembly?
Old Jun 3, 2007 | 04:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 2 PCV valves?
Its part of the PCV system .
Old Jun 4, 2007 | 01:00 AM
cesspool's Avatar
cesspool
That really doesn't answer my question....
Old Jun 4, 2007 | 01:03 PM
hydrashocker's Avatar
hydrashocker
I'm not to sure but I think that is just a crank case vent.If it has a bigger line going to it then the PVC valve then I'm very sure that that is what it is.
Old Jun 4, 2007 | 01:09 PM
master tech
You only have one PCV valve and a vent return to the air cleaner.
Old Jun 4, 2007 | 01:55 PM
cesspool's Avatar
cesspool
So just a breather?
I thought that's how it should be, but it is identicle to the PCV valve in appearance.
Old Jun 4, 2007 | 03:05 PM
jonnymagnum's Avatar
jonnymagnum
its only a vent.it goes into the air breather. and it uses a bigger hose then the PCV valve.
I replaced mine acouple weeks ago. their computers dont list these. so I went out to the parking lot and took it off. then found one similar.
Old Jun 4, 2007 | 04:17 PM
cesspool's Avatar
cesspool
MY valve gaskets are going to need changed out this summer sometime. I was going to replace that stuff and maybe soem some fancy smancy valve covers Too. And now perhaps a little breather too!
Thnaks guys!
