Bolt pattern, torque specs..
95 to100foot pounds and there two type of lug nuts 3/4=19mm or 13/16=21mm. 5 bolt pattern is done in a star pattern and 6 lugs on crossing pattern.
thanks! So the Durango's came with 2 different size lug nuts? I need to buy a socket wrench that's why I'm asking. However with regards to the bolt pattern I was referring to themeasurement aspect of the bolts in relation to each other.
I googled it and it came up with a bolt pattern of 6/114.3 Is this correct?
http://www.discountedwheelwarehouse...._Reference.cfm
