front differential
If it is like my 01, the rubber fill plug is on the front of the cover just to the passenger side. As stated above, I recommend using a pump to empty and refill the pumpkin as the cover is no less than a POS to remove and install.
I cannot comment on the skid plates as my D does not sport them.
As an FYI, I have run both Mobil 1 and now the Royal Purple and I was able to get the RP locally at an RV dealer for less than $9 a quart.
Good luck Don
Good luck Don
PITA. You'll definitely have to ull the skid plate to get it off then after draining the fluid you'll have to get the cover back on while avoiding everything that is in the way so you don't scrape your RTV off of the edge. After you get it on then you'll run ito the problem that you can't get the whole bottle of fluid into the diff. I know that they have some hand pump??? that you can use to get all the fluid in there easier but everything else isn't gonna be as easy. I prefer pulling the cover rather than sucking it out with a pump because then you can check the gears for abnormal wear and address any issues that may arise...
