It depends on your application. If you do a lot of towing I would go with the add-a-leaf, it will provide extra support on the rear. If you just want to maintain the same ride then go with shackles.
Thanks Mean Green, you had replied to a similar question I had several months ago, i did not remember what you had said.
Another quick question. I also need to replace the shocks all around. Would I use the same size shocks once the durango is lifted or would the shocks differ? Also, do I have to change brake lines and so?
