is my blower switch going bad?
Old Jul 31, 2007 | 09:31 AM
M Shark's Avatar
M Shark
Default is my blower switch going bad?
Last month the first setting on the aircon blower **** didn't work. Now it's the 1 and 2 setting. Right now I'm always putting it on the 3rd setting. I'm just wondering if it's just the switch that needs replacement.
And does anyone have a write up on how to change it?
Old Jul 31, 2007 | 11:42 AM
hydrashocker's Avatar
hydrashocker
Default RE: is my blower switch going bad?
Do a search on blower motors. It should just be the resistor. Look in the 1st gen durango section.
Old Jul 31, 2007 | 10:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
The blower resistor needs to be replace, because the resistor is what gives you the diff speeds. You will find it under the dash on the passager side.
Old Aug 1, 2007 | 01:41 AM
IndyDurango's Avatar
IndyDurango
ditto +3
Your blower motor resister is blown. Easy fix since it doesn' require replacing the blower actually. Search for instruction.
IndyD
Old Aug 2, 2007 | 09:37 PM
M Shark's Avatar
M Shark
alright thanks guys! I'll get the part tomorrow and fix it.
