Help - Where is the crankshaft position sensor located on a 2000 Durango
Old Aug 13, 2007 | 04:33 PM
webdzynes's Avatar
webdzynes
Default Help - Where is the crankshaft position sensor located on a 2000 Durango
[align=left]Its throwing codes 320 and 725 which point to the CPSA but I dont know where its located. Its a 4.7 liter... Anyone know?
[/align][align=left] [/align]
Old Aug 13, 2007 | 05:13 PM
dodgepartsman's Avatar
dodgepartsman
Default RE: Help - Where is the crankshaft position sensor located on a 2000 Durango
found a tech tip on this, maybe it applies:
[align=left]Tech Tip Part Description:Crankshaft position sensor[/align][align=left][/align][align=left]Tech Tip Description: the crankshaft position sensor target / tone wheel tooth position learn for the engine misfire detection is a "stored value" and must be relearned: If engine controller is swapped, engine/crank/short block is replaced without engine controller, or the crank sensor is removed for inspection / diagnostics, tightened, or replaced. Perform an (ECU / PCM) engine controller module RESET using the STAR SCAN service tool. Some PCMs will not reset with a battery disconnect. After resetting perform three closed throttle coast downs from 70 mph to 40 mph. This procedure will force the PCM to perform a crank position relearn. Failure to perform the above could result in misfire detection. [/align][align=left][/align]
[IMG]local://upfiles/64653/C527384842684C1D839BBA5AE5903CFF.gif[/IMG]
Old Aug 14, 2007 | 12:38 PM
steve05ram360's Avatar
steve05ram360
the crank sensor should be on the back of the block where it bolts to the transmission on the passenger side... right behind the passenger side head. IIRC takes an allen wrench to remove the bolts.
