'Click' When I Try to Start - Battery is Good
Old Sep 3, 2007 | 01:10 PM
mickinirvine's Avatar
mickinirvine
Default 'Click' When I Try to Start - Battery is Good
Any ideas? It did it once or twice sometime back, but now when I go to start my 99, 5.9 it clicks and will not start. The battery is good and plenty of power is available. If I go back and try to start it again after a while, the car often starts.
Is this an issue with spark plugs or a sarter or something else? Any ideas?
Old Sep 3, 2007 | 01:26 PM
Mean Green's Avatar
Mean Green
Default RE: 'Click' When I Try to Start - Battery is Good
Definitely your starter. This is a pretty classic example of how you can tell when a starter is going out. Definitely get it replaced ASAP or you'll end up stranded one day as it will not work at all.
The only other thing I could think would be a bad connection but with a bad connection and that click all of the electrical on the truck will cut out for about 30 seconds or so.
Old Sep 5, 2007 | 06:42 PM
billdixon's Avatar
billdixon
Its your starter.
Old Sep 6, 2007 | 08:02 PM
CowboyBob's Avatar
CowboyBob
My diesel did this and it turned out to be the contacts in the starter. Bought the parts from www.fixinrams.com for $39 and it took about an hour to do. Beats the price of $189 for a new starter.
Old Sep 9, 2007 | 10:30 PM
mickinirvine
Ive been at trying to get the old starter out for hours! The angles are tough, but the mounting bolts are on so tight I can't move them. I've used about half a can of PB Blaster, but still nothing. Every muscle in my body aches from pulling under the car. Any suggestions?
Old Sep 9, 2007 | 11:33 PM
Mean Green's Avatar
Mean Green
Maybe try a breaker bar?
Old Sep 10, 2007 | 12:19 AM
durangeddurango's Avatar
durangeddurango
righty tighty lefty loosey.....
