Fan Clutch removal problem
Old Oct 5, 2007 | 08:29 PM
Kilus's Avatar
Kilus
Default Fan Clutch removal problem
Howdy all,
I am in need of some Dire help please.
I own a 1999 Dodge Durango and the fan clutch is my problem area.
The clutch finally went out and I for the life of me can't keep the pulley from moving to break the nut in the back. could anyone please give me some advice on how to keep it from moving. I am seem to be doing everything I can only to fail.
Thank ya Kindly in Advance
Old Oct 5, 2007 | 11:14 PM
steve05ram360's Avatar
steve05ram360
Default RE: Fan Clutch removal problem
couple of things you can try... if the pulley bolts to the pump, wedge a screwdriver between the bolts & then torque on the clutch nut, if not, you'll need to get a strap wrench to hold the pulley while you loosen the nut.
welcome to DF...
Old Oct 6, 2007 | 03:11 PM
adheliajon's Avatar
adheliajon
Take a 3 pound hammer and give your wrench a few wacks and it will come loose!!! Thats what i did to get mine off.
Old Oct 6, 2007 | 10:08 PM
cesspool's Avatar
cesspool
You have to keep the pully from turning to break the bolt free. like steveo said, strap wrench works great for this job. there is a special tol though that you can probably get from the zone for free to use.
Old Oct 7, 2007 | 09:43 AM
20durango00's Avatar
20durango00
I did this on our '00 D, got a strap wrench from Autozone, held pulley, worked great, good luck.
Old Oct 7, 2007 | 06:44 PM
Yellow Runner's Avatar
Yellow Runner
all i do is takea bar and ahammer and hit the nut right on the edge a few times i never have no prob with the pully turning.
Old Oct 15, 2007 | 09:36 PM
dragrcr1962's Avatar
dragrcr1962
Oh man!!!!! Nobody has told you yet???? It's a REVERSE thread!!!
