Old Aug 5, 2015, 08:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Squeaking noise.......
Old Oct 8, 2007 | 02:43 PM
niftyguy239's Avatar
niftyguy239
Default Squeaking noise.......
I hate squeaking noises and my D has done nothing but that the past few weeks..... here's the delima....
3 weeks ago I was backing out of my driveway and went from the driveway to the road where there is a little curb, well after I went over the bump it made this almost deadly squeaking noise. It's loud enough you can tell its squeaking a few hundred feet away. I took it to the shop, they said it was a combination of my ball joints..... 800 bucks to replace all both upper and lower and the shocks. I did those myself replaced with Gibson Performance Pro's. anyway, So I started thinking, it must be the control arm bushings, Replaced both upper and lower on the right side, (sounds where its coming from most) and it still is squeaking just as bad.....
Anyone care to add any suggestions?
Old Oct 8, 2007 | 03:29 PM
United1's Avatar
United1
Default RE: Squeaking noise.......
Did you check the sway bar bushings? Common for them to go, causing squeakin and creakin.
Old Oct 9, 2007 | 01:59 AM
Mean Green's Avatar
Mean Green
Sway bars are most likely the culprit...
Old Oct 9, 2007 | 11:26 AM
Kensai's Avatar
Kensai
you can only find a complete replacement bushing set from the dealer. Not expensive tho, i think it only ran me around $40 for the whole bushing set. I wanted polyeuthane type to last forever, but they don't make a set tailored for the Durango. You have to do your own measurements and what not to get the right custom bushings for your sway bar.
No more squeakies for me.
Old Oct 9, 2007 | 12:46 PM
niftyguy239
Thank you guys so we talkin about the bushings that connect the sway bar to the A frame (control arm) r the bushings that hold the sway bar to the frame?
Update: I see that all the bushings needs to be replaced.... Thank you........... howdo you get the front sway bar bushings off? Cut them??? Also, found the loudest culpret.... drivers side front lower control arm bushing....... the one i haven't replaced......
Old Oct 9, 2007 | 01:16 PM
Kensai's Avatar
Kensai
I watched my buddy mechanic took my swaybar off and the bushings just slide off. Man, they are dry rotted and hard as a rock.
Old Oct 10, 2007 | 01:53 AM
Mean Green's Avatar
Mean Green
Just a little FYI Ken if you want the polyeurethane bushings do a good search on the net. I found a set for cheap a while back when I first got the D and was looking for mods to do to the beast.
Old Oct 10, 2007 | 02:18 PM
Kensai's Avatar
Kensai
ORIGINAL: Mean Green
I spent over a week on the net looking for those bushings while my D was in the shop having its tranny replaced. Everyone came back to me to measure this and that and this and I just said forget it, too much work and so little time. I wanted a oem fit replacement without going thru all the hassles. So I just went back to OEM bushings as most part stores like NAPA and carquest did not have the complete inner and outter bushings for the swaybar.
Old Oct 11, 2007 | 06:11 PM
durangeddurango's Avatar
durangeddurango
here you go
[/align][/align]
CONTROL ARM BUSHING
Today's Price:
$47.16
Qty:
MANUFACTURER:
ENERGY SUSPN
PART NUMBER:
53122G
SHIPPING SURCHARGE:
NONE
SHIPPING INFO:
Orders ship within 1 - 3 days. Delivery time based on shipping method selected.
Old Oct 11, 2007 | 06:29 PM
Kensai's Avatar
Kensai
where isthe complete set?
