Cost of transfer case seal replacement?
Old Oct 25, 2007 | 02:18 PM
Kidd_Funkadelic's Avatar
Kidd_Funkadelic
Default Cost of transfer case seal replacement?
When the 2000 Durango 5.9 R/T I just bought was in for an inspection, the dealership said the transfer case seal has a leak in it (not enough to leak on the floor of my garage, and specifically they said in 3 places, 2 in the front or 1 in the rear or something?) and that I really would be wise to address this before winter when I'd be using 4x4. They said that the fix involved dropping the transfer case and would cost $600.
Is this a fair ballpark figure or should I search elsewhere for a lower price???
Thanks,
Kidd_Funkadelic
Old Oct 25, 2007 | 08:50 PM
n8ech's Avatar
n8ech
Default RE: Cost of transfer case seal replacement?
Kidd:
That price does not sound too far out of line,but check around and see what kind of a bid other shops might give you. That quote sounds like what a dealer might charge. My local star wanted $600 just to swap out my full time 4wd case and remove the part time unit.
Highway robbery!!!!!!!!!!!!!!!!!!!!
Don
Old Oct 26, 2007 | 11:15 PM
master tech's Avatar
master tech
Site Moderator & Tech
The seal that leaks on your transmission tail housing cost about 10 to 15.00 dollars if that. I would ask what is there labor rate per hour. Labor should be 2 to 2 1/2 hours.
