318 360 swap
I swapped a 318 for a 60 over, ported/polished 360 in my 99 durango. I had to change the shortblock, the harmonic balancer, and the flexplate. My problem is the computer. How can I get the computer reprogramed to the 360 engine? Will an aftermarket reprogrammer do the trick or do I need to figure out an oem solution (the dealer--BLAH!!!!!!!!)
I would just leave it but it is starving at higher rpms, and feels like its missing also.
thanks
Brent
thanks
Brent
looking through the archive threads and someone mentioned
who makes a good one? any reccomendations?
for $250 he can get a custom ECU im still not seeing a problem.......he obvisously knows what hes doing so i'm sure he alraedy knows his option as far as ECU reprograming/custom setups will run
If I remember all the responses to another similar mesasge post. You will need to replace the PCM. The PCM's for the 318/360 are different. I cannot remember the exact details but I think I am sure you will have to go with a replacement PCM designed around a 360. But seeing as you have a custom built engine, you may need to get a custom programmed 360 PCM module.
I have been here before and I beleave the computer was flshed by B&G to include the new perameters. The parts listed were replaced but I think that was it. I had a person do this not too long ago. Do a search. I tried but no sucess. I'll keep trying.
Trending Topics
I did a site wide search and a google search but cantfind a reprogrammer or aftermarket pcm that any recommends.
Kensai, i realize the pcm's for the 318/and the 360 are specific, and I need to change mine,, my question was can you reccomend one. I guess I will look up this B&G and see what they have to say.
sixty six, to be honest I have no idea if the heads were reconditioned 318 or off a 360. I assume they were 360 heads but the engine shop could have given me 318 heads and i would not have even known. Are they even exchangable??? if so how bad is that hurting my performance? Whatever headsI haveI ported up perfect and polished the insiderunnerslike a mirror. lol
I will seach for B&G.
Thanks fellas
Brent
PS. I have been running the 318's computer on the 360 for 12000 miles now and it works ok with ok milage. BUT!!!!!! I have NO HP or TQ @ mid to high range. I am getting a 16ft camping travel trailer (6500-7500lbs)and need all the HP I can get.
Also, when I rev the engine up past 3800rpms the check engine light comes on and throws a fault code, cylinder 2 and 4 misfiring. (unplug the the battery for a couple mins and it will erase and go back to normal)
Thanks fellas
Brent
