01 durango 4x4 problems. Fixed!!
Old 01-16-2008, 08:05 AM
deerang's Avatar
deerang
deerang is offline
Default RE: 01 durango 4x4 problems
glad to hear all went well... $53 and some wrench time sounds a hell of a lot better than going to the stealership
Old 01-16-2008, 01:45 PM
n8ech's Avatar
n8ech
n8ech is offline
CTFF:
Glad to hear that you got it fixed. Chalk up another repair done cheaply and easily thanks to the collective braintrust that exists here and on a few others sites to support us as Durango owners.
My 01 has not had this issue as of yet at 67k, but lately more and more 01, 02 owners seem to be having it. Hopefully if it is going to rear its ugly head it will do so before Feb. of 2009 when my warranty expires.
Don
Old 02-12-2009, 07:00 PM
45romeo's Avatar
45romeo
45romeo is offline
Default Diagram Please
Hello CTFF,
If you can email me the diagram of where the TCCM is located I would appreciate it. I am about to undertake this project.
timdodds at live . com
Thanks
45romeo
Old 03-25-2015, 10:33 PM
bjjshawn2012's Avatar
bjjshawn2012
bjjshawn2012 is offline
Default 4x4 issue probally electronic
for a while now everytime i start my car my 4x4 light on dash will be on and stay on disengaging my **** and no lights on ****. after my durango warms up and is running the light will go out and ill have what seems to be full use of my 4 wheel drive. green light comes on to indicate im in 4 wheel drive and then i can switch it..... usually before the 4x4 light goes out after warming up it will go on and off for a few minutes then stay out giving me back use of my four wheel drive. ive checked my fuses and all good. i have not really started to look around and check cause i dont know where to go or what to do... all i know is it seems to me temperature sensitive and elecronic... for example if i just start my car and its warm and or hot outside the 4x4 light will not come on and stay out and be normal...i could use some sense of direction. all i know is this started close to around the time i replaced my gear oil and gaskets on my front and rear diffs because i was having issues and noises but diagnosis went pretty well eith examing teeth on gears and so for forth. btw i have an 01 durango 4.7 liter v8 magnum 4x4... any help would be great
Old 03-25-2015, 10:36 PM
bjjshawn2012
Default 4x4 light on instrument cluster issue
coming on and off. i dont know where to start except check things around my front diffential maybe a vaccum line and or something i may have disrupted replacing the gasket and gear oil on my front..... need help!!
Old 05-26-2016, 12:31 PM
N.Y.X.'s Avatar
N.Y.X.
N.Y.X. is offline
Thanks for the info!!
Quick Reply: 01 durango 4x4 problems. Fixed!!
