Just bought a 98 durango possible tranny problems
Old Jan 14, 2008 | 10:19 PM
OddBall85's Avatar
OddBall85
Default Just bought a 98 durango possible tranny problems
I just bought a 98 durango with the 5.2 and on the drive home I noticed that it was shifting late but if you let off the gas it would shift does it through all gears I dont know if its that the o/d isnt working there is no o/d light on (if there is one) when I play with the switch nothing seems to happen
Old Jan 14, 2008 | 10:22 PM
Duranged408's Avatar
Duranged408
Default RE: Just bought a 98 durango possible tranny problems
Congrats on the purchase. If you dont mind hows the miles? and by chance dealer or personal purchase? 4x4?
Old Jan 14, 2008 | 10:23 PM
OddBall85's Avatar
OddBall85
136000 and some change and from a tow yard when I went to get my other car and its the 4x4
Old Jan 14, 2008 | 10:30 PM
Duranged408
(O/D button is on the shifter end and a light should indicate on dash) despite the info i can throw up a few possibilities and checks, first off the fluid. See how she looks (Some D's are required in N to check others Park) low/high/due for a change. Second, usually late shifts are due in part to a mis-adjusted throttle valve cable. A thing i mention to everyone, and highly recomend is a purchase of a repair manual for any vehicles they own. Its simple for me to suggest fixes but the repair manuals can detail the information aswell provide pictures.
Old Jan 14, 2008 | 10:34 PM
Duranged408
Now readin up, does it seem to downshift during part time throttle early?
Old Jan 14, 2008 | 10:38 PM
OddBall85's Avatar
OddBall85
the o/d light doesnt come on at all but yeah Ill definitely get the manual tomorrow
Old Jan 14, 2008 | 10:47 PM
OddBall85's Avatar
OddBall85
I think it stays in gear till you let off or slow down enough and kind of uses the gear to slow a little as if it was towing something
Old Jan 14, 2008 | 10:49 PM
Duranged408
Alright good deal. My last idea, that i was saving after the intial checks is the governor solenoid. Look it up around the web/forums and see if the symptoms are the same (BUT still check your TV cable and fluid. A new filter and trans fluid never hurt, just dont get it flushed and never use anything else cept ATF+4. ( And whenever you do a transfilter its always good to get the bands adjusted- Honestly i do everything myself except the transmission bands, i bring it somewhere)
Old Jan 14, 2008 | 11:01 PM
OddBall85's Avatar
OddBall85
I hope its a simple fix thanks for the advice
Old Jan 15, 2008 | 10:26 AM
Duranged408
Fixing is always quick and simple. Now diagnostics are 99% of the trouble. [sm=confused06.gif]
